Good info Isra! :thumbsup:
Why would you need two wastegate for just one turbo? It's unnecesary to have 2 wastegates for just one turbo, besides, it wont work. Now, if you run twin turbos, then you would need 2 wastegates, one for each turbo!seawalkersee said:You have sparked a few questions with me. If you have a problem with the boost spike, what is stopping you from running two wasteg8s? If you have two and both have a five psi spring, that should take care of it yes?
Chris
P.S. Where did you get your book...its time I joined the game again.
seawalkersee said:If they are mechanical why cant you use two. Only one would pop if it reached the pressure. However in the event it spikes then they would both open. I dont know this for a fact thats why I am asking...Again...where did you get your book? I want it.
Chris
seawalkersee said:So if the wastegate opens then why does the boost spike happen?
Chris
Sir William said:I'm not aware of having any boost spike. Why would you state something like that when you have no basis for the statement.
Thats not necessarily true. When you start making some serioues serious power, sometimes twin waste gates on a single turbo setup are required in order to handle the sheer volume of exhaust gases thats need re-routed around the turbocharger to control boost creep or boost spikes. Jon Dell Blair's 86 SVO is a perfect example of this.Tx_Cat said:Why would you need two wastegate for just one turbo? It's unnecesary to have 2 wastegates for just one turbo, besides, it wont work. Now, if you run twin turbos, then you would need 2 wastegates, one for each turbo!
You can have them sequential or each turbo per manifold. Supras have a sequential setup, so as the new F350. In my opinion, I would not use a sequential setup. Many say that it's very inefficient. That's why many supra people get rid of them and put big singles.Dumb newbie question here. Would twin turbos be sequential or are you talking about having one on each side of the manifold?
Well, I'm not gonna argue, but I see LOTS I disagree with. Let's just say I'm planning on doing twins, and doubt highly I'll use ANY waste gate. I might also point out that BOV's and waste gates essentially do the same thing, and Ak Miller was using at least 3 BOV's on a single turbo 30 yrs ago, all at the same rating/design too.
Yeah... That's an understatement....
Wastegates and BOVs perform completly different functions....go luck with your project.
David
It is interesting that the US is insisting that the EU wipes out its debt to Iraq in order to help recontstruction. Presumably so iphone can be indebted itself.
