1 - 11 of 11 Posts
ok i guess the wire for the O2 sensor in front of the cat on the passenger side is longer than what the replacement ones i bought were. what brand O2 sensor can i get that is that same length. i got the Bosch one and it went in perfectly on the driver side but the passenger side was a *****. ASAP!
get the bosch ones. when i replaced mine, i was worried that the wires wouldnt be long enough. but i got the replacement ones and they fit fine. you may need to tug on the connectors so they will reach.
It doesnt hurt anything to extend the wires if you really need more. Tape them up good to keep out water though. I put bosch on my '92 3.8 back in the day and had no problems.
-Rob
is there a extension harness i can buy for them
Confirmed V6 Nut
nope. You could try trading in the one you have for a universal fit Bosch O2 for your car. Then you splice the connector on to the wires. The universal fit O2 has longer wires.
noooooo universal = bad. They operate at a wider range to comply with different computers on different cars, and this makes them less accurate. They make Bosch OEM fit ones with a long wire, I've seen it in the computer at work.
-Thomas
so then how am i gonna find a replacement O2 sensor for the passenger side before the cat without having to do anything to the wires
autozone, advance auto parts, o'reilly's, etc. the replacement ones are a direct swap, no cutting and splicing of wires needed. did you try tugging on the connectors some? i had to tug on mine some to make them "click" together.
and like I said, my computer at work (o'reilly) listed 2 OEM replacements, one with a longer wire.
-Thomas
man you can cut and splice for probably 2 dollars for a whole roll of the wire youd need...it will NEVER give you a problem because given enough slack nothing pulls on them they just lay there...
its a 3minute/ 2dollar fix
good luck figuring it out let us know what you come up with
1 - 11 of 11 Posts
