The Moog and Masterpro brands from Orielly, the Rare Parts brand from Advanced Auto and the Duralast bushings from Autozone are all blue plastic and look just like this when new.
All junk to be avoided.
Here are the Drive Works
rubber bushings. Assuming these pictures are correct, they appear to be cut from a solid piece of rubber, unlike the Ford 2 metal pieces bonded togther in rubber. This Drive Works design
may be okay, but your still stuck using those weak split sleeves that tend to distort.
Their bushings for the other end of the strut rod are blue plastic like above.
Here are the TRW bushings. The rear ones use the same picture as the Drive Works above. Does that mean they are the same part? IDK. The fronts look close to Fords, but without the metal ring molded to the one bushing, but they still use those weak split sleeves. These pics may not even be correct.
So to summarize, the plastic bushings do this:
and the weak split sleeves do this:
That's why I went with original Ford bushings. Plus they weren't too much more in cost compared to these aftermarket ones.
