SilverBird02 said:
It only happen's when I turn to the left. It's like a hollow popping sound. I think I can feel it in the pedals also.
The weakest point of our suspensions are the Upper and Lower Ball Joints and the tierods ends.
Get the front off of the ground (up on Jack Stands) and see if you can move the hub and rotor by lifting it. Watch the top Ball joints to see if they are loose. If they are, replace them ......... Do the same with the bottom ones and the tierod ends. If everything is bad, hold on to your wallet. (I did this with my SC two years ago), It will run about 8 bills to get it done at a shop!
Michael Albee - Prez
Super Coupe Club of Iowa
http://www.sccoia.org
