Okay, so I was checking out my front tires and noticed that my drivers side front tire has a really bad uneven wear. The outside edge of the drivers front is wearing out much faster than the rest of the tire. There's a strip about 2 inches wide that has all the tread worn down, while the rest of the tire looks good. The passenger side is completely normal. Does this sound like a camber issue? I know the alignment is off slightly, but I figured both tires would show wear with an alignment problem.
And, if it is a camber problem, is this something I could correct myself and how?
Thanks
Thanks
