Edit I changed the name of the thread due to my latest research. See post #4 below.
I'd like to figure out what exactly I want to do with my front inboard (i.e., adjacent to the grille) lights. But first let me tell you about my day:
Today was so much fun, because I went to a pick & pull yard for the first time ever. I've been to "conventional" junkyards, but this is so much cooler. I mean they give you a wristband; it's like going to a nightclub, and nobody keeps watching over your shoulder.
I picked up some chrome door knobs (because I love bling - don't judge)...
...and these three-prong plugs/harnesses, which brings me to the topic of this thread:
The Factory Setup
As you all know, the inboard parking lights in the front are just that: parking lights. That was just a waste in my opinion, since there are already parking lights at the corners.
The Current Status
Currently I have white 3157 Zevo LEDs in this spot. I modified the plug by moving the parking pin into the major slot, i.e., the LEDs run on the bright LEDs when the parking lights are on.
My rationale for this was that I would use the parking lights as DRLs. While that works great during the day, the problem is that the LEDs are too bright at night. I absolutely hate cars with lights that glare, are ill-aimed, etc., so I don't want to be guilty of doing that myself.
Changing the plug back to running on the minor pin would not really help, because then the LEDs would be quite dim for DRL duty. (Zevos have great contrast between the Major and the Minor LED).
What I Want and Don't Want
Option 1
Disadvantage: No real DRL function other than driving with parking lights or just driving with headlights on during the day.
Variation to Option 1
Option 2
Disadvantage: This seems complicated. I'm not even sure where to source such a DRL module, and then where to get ignition power from in the engine compartment.
Option 3
Disadvantage: I'd probably constantly forget to turn off my DRLs.
Your Thoughts?
The best in my opinion would be some combination between option 2 and 3, i.e., something that doesn't require an additional module under the hood, but that has some level of automation (auto on with ignition; auto off with headlights on). How can I accomplish this? (Does anyone have a wiring diagram of the headlight switch by the way?)
The Factory Setup
The Current Status
- With the three-prong harnesses/plugs I picked up at the junkyard, evidently I want these lights to have dim and bright functionality going forward
- I do want some sort of DRL function (but it does not have to be automatic)
- I like using LEDs in general, but I don't really want to add any resistors
- For the High/Low beam headlights, I want to keep incandescent bulbs; I don't really trust LED replacements, especially considering that their cooling fans would be exposed to the elements inside the engine compartment
Option 1
- Make front inboard lights amber incandescent parking and turn signal lights
- Make front inboard lights amber LED parking and turn signal lights (while corners remain incandescent)
- This would effectively give me front sequential turn signals because the LEDs light up faster
Option 2
- Keep the white LEDs, but install a DRL module
- DRLs would use the bright LED elements; parking lights would use the dim elements
Option 3
- Same as above, but without the DRL module
- I would run a wire through the firewall and place a switch on the dash
- This would control the bright LED elements in the inboard lights for DRL duty
Your Thoughts?
