121 - 136 of 136 Posts
Not sure, Rod may know. They are Performance Artworks, I couldnt find a website i think they have a facebook page to contact
Here it is but I think it's old.
I thought I remembered seeing somewhere they weren't selling direct anymore.
Discussion Starter · #122 ·
Now that my red cars build is wrapping up I plan to pick this up again. I have 4 separate options Ill be trying within the coming months so long everything goes to plan.
Which is not exactly likely nowadays. But still, thats the plan.
The gto inserts are showing 145 ea on walmart.com !!
The gto has a 55/45 weight split, and is 3600 lbs. That's achievable.
Looks like shocks to me...
OOPS!. ;) The fronts are struts. Yeah, that pic was from a straight axle swap, lol.
1991 Mercury Cougar LS 5.0 in restoration
I need some specs. Not a huge fan of the orange, but specs are more important. If it works, it's interesting...
What is that second lower nut for? Locking for the " height" adjusting nut?
And why 2 top hats?
Discussion Starter · #134 · (Edited)
And why 2 top hats?
Specs are this: specific to MN12s.
These are purpose built for our cars.
Springs are 14kg per MM, or 784lb per inch.
There isnt a top hat at all anymore, just an upper spring perch and an upper mount.
Yes the bottom nut is to adjust ride height oncr you have the springs loaded to your desired setting.
Edit: Ill explain more. I was a bit too excited to do so at the time.
These are a set of MaxSpeedingRods coilovers.
It is widely known they arent a quality company. Im not too concerned on that front.
What I wanted were the upper mounts, the lower mounts, and the spring kits.
I got both sets for $335 shipped.
I will torture test one set in the drift car. Cause why not, I wanna see how they compare to 170k mile Sports with chopped SC springs.
The other set will be getting dismantled, and Ill be looking to essentially copy the mounting hardware, find where I can get the spring kit, and will be finding replacement inserts. Quality coil over companies sell replacement inserts, Im sure theres one out there.
I bought a set of koni cobra rear shocks about a month ago; they look identical to the ones on Lazarus.
  • Like
Reactions: Zep5.0
