Need the number for the 3 bolts on the front assembly. I sheered one. No, its not the tie rod end or the sway bar bolt. The bolt that sits by the caliper. No pics available at the moment.
Part number is all that is needed.
Thanks.
I'm not sure which bolt you need:
Caliper Bracket Mounting bolts (2)
Lower A-arm to shock (1)
Lower A-arm to frame (1)
Upper A-arm ball joint "pinch bolt" (1)
Upper A-arm to shock tower bolts (2)
Those are the only true "bolts" that I can think of (off the top of my head) that are on the front suspension.
The only "three" things that could be considered "bolts" are the studs on the top of the shock mounting assembly. Those are studs that are part of the shock mount assembly. (I think)
The only other "three" things I can think of are the "rivits" that hold the rotor dirt shield.
More info is needed. :thumbsup:
