I cannot get this nut off....its the one on the subframe. any suggestions or advice would be helpful
I took mine to a local Midas Muffler shop, and paid the guy $20 to loosen them.
If you can get the car in the air high enough, a 3ft. lg breaker bar on a 1/2" drive 30mm socket bit will do the trick.
I used a crescent with a pipe on the flat and a breaker bar with a pipe on the nut and it took two people.
FIRE WRENCH! actually thats what i had to do on the s/c i built for my uncle .i had to heat them up with the oxy , came right off.
The nut is the easy part, wait till you try and get the bolt out.
What you could do, is go to a shop and have them loosen the nut, remove the bolt, clean up the bolt, and have them put everything back together. Repeat for the other side.
It took an air-hammer/chisel to get those bolts out of my car when we did the springs this spring.
kevin we sell lots of lca's for just such reason!
I just used a 30mm wrench, and a lot of muscle. Well, I had to cheat and use my feet to get them to break loose;)
