There is a nice sticky at the top of this thread. Other than that you would need to give a little more info on the symptoms. I have a noise that I am pretty sure is the sway bar endlinks. I plan to replace them again and see. It only makes noise when it is an uneven bump like one side goes over a speed bump and the other does not. No noise if both sides go over the speed bump. This is just a for instance. I have had clunking from ball joints also. The front suspension on these cars needs a lot of care and feeding.
