hi, looking for some help, with a squeaking noise on front end of my t-bird. have replaced almost entire front end with new parts.uca,lca,ball joints,inner,outer tie rods, struts,rack pinion, all bushing,end links etc. have grease every thing that has a fitting. squeaking noise is constant, never stops. and the squeaking noise was there before , i started to repair the front end. any ideas of were to look first, or what to check. thanks.
hi, thanks for the info. i read that thread also. i have read about 100 different threads about the front end issues/problems. before i decided to post. i also forgot to mention that i replaced the sway bar bushing with engergy suspension bushing with greaseable fitting. thanks
