1 - 1 of 1 Posts
Hello,
I have a 95 tbird lx with the keypad entry on the drivers door. recently, i went to lock the car after using the keypad to open, and it wouldnt lock when i pressed the button. in fact, i found i couldnt press the lock itself down, and it would not turn with the key. i noticed it would unlock, by moving up just a little bit when i pressed the button. i removed the door panel, and sprayed some liquid wrench on the solenoid near the bottom. it loosened up and started functioning again.
however the keypad was used again today and it seems frozen in the unlocked position again. is this something with the solenoid, or the keypad? im not sure if its even the keypad, but i havent noticed it with either the remote or normal switch on the door. thanks for the help in advance!
1 - 1 of 1 Posts
