Status
Not open for further replies.
FOR SALE: 1996 Thunderbird LX 4.6L V8 with Sport Suspension $ 2,950.00
Forest Green with Gray cloth interior, 186,xxx miles, everything works, cold A/C
Non-smoking adult owned, well maintained, no known damage history, clear WY title
The car has Sport handling suspension shown by JJJJ spring codes on the door jamb label, which may have also included the relatively rare 5-spoke wheels. The original AM/FM stereo radio comes with it if you prefer to pull out the Kenwood AM/FM/Stereo cassette with trunk-mounted 6-disc CD changer system. I'll remove the ham radio on the console ahead of the shifter, and can either take off the trunk antennas & put in hole plugs or leave the antennas in place (I think they add a rakish look to the car, myself; they’re OK for car wash). Speedo has been converted to the SC 145 MPH scale as per the article I wrote on it for TCCOA awhile back and the oil pressure gauge has the conversion to true gauge reading. A Cobra 360 Laser4 Superwide X/K/Ka/Laser detector mounted above the inside mirror is hard-wired for automatic On/Off operation.
Car comes with factory shop service & powertrain controls manuals, OBDII manual as well as 4 new original Ford struts & shocks still in the box, along with extra parts like interior trim pieces, console top and rust-free Teal deck lid shell. It runs very well, did new plugs & wires last summer. It will occasionally throw a Check Engine light, PCM code indicates right side cat converter may need replacing at some point. The 2 fog light switches on the console control the front alternating high beam headlights and the rear alternating stop & backup flasher systems, they can be left functional or taken out, your choice (I was with County Search & Rescue for awhile, back in the day).
The car has very little rust on it, a couple of small spots ahead of the rear wheels but that's all. My understanding is the car originally came from Orlando area then went to Denver for a year before I bought it in February 2004, after which it's summer-only driver. Clear-coat is faded on the upper surfaces, probably from FL sun. Michelin tires on the rear in good shape & new ones on the front. Car also has Daytime Running Lights mod that uses the inner turn signal bulbs.
A couple of options on delivery -
- pick up here in Cheyenne WY before July 12 moving day or
- pick up in The Villages FL after July 18 or
- free delivery on our move from WY to FL; route is flexible, can be north via Linc-KC-STL-Nash-Chat-ATL-FL or south via Den-Pueb-Amar-DFW-Shrev or Hous-NO-Mob-FL.
Will drive it from Cheyenne to you, delivery to be within 50 miles of the agreed-upon North or South route.
The “drive it to you” delivery option will require a $250 non-refundable deposit in advance, fully credited to the purchase price.
Contact Larry by cell at: 307-630-5697 or email me at: [email protected] for more pix.
Discussion Starter #2
A few more pix ....
Status
