1 - 20 of 27 Posts
Has anyone done anything new with fuel tanks lately? I'm currently debating a switch to a fuel cell or the addition of a surge tank.
At the moment I'm running dual 450s in tank ( one full time and the second via hobbs switch. But they are a royal pain in the ass to get in and out not to mention having to keep half a tank of fuel to launch the car safely. Any ideas guys?
I'm debating a cell on my build. Biggest factor against for me is the smell and vapors. I'd like to still run the fill tube to eliminate this issue, but not sure there is enough drop to the fuel cell without it scraping on the ground. I think transferring the weight back would be great.
The other benefits of is you could run subframe connectors to the IRS frame and put mufflers in front of the rear.
Horsepower TV did a Tbird years back and did a sweet subframe. Looked very functional and game much more room for exhaust.
Why so much fuel? I'm only running one FORE 405 pump.
What size injectors are you running?
Discussion Starter #4 (Edited by Moderator)
I know people have put them in the spare tire well, but if its in the trunk I believe you have to install a divider behind the rear seat. I'm sure you could figure out a way to get the fill tube into the trunk (possibly through the side of the spare tire well?
The main thing deterring me is the ******* intercooler tank that I have in there right now.
To make power Ron!!! I think you are probably getting close to the limits of a single 405.
ID 1000
Probably, yeah. Rob did say that if I wanted to put a bigger blower on the engine I'd have to completely upgrade the fuel system. He also noted, while we were tuning the new build, that I'm also almost out of MAF sensor capacity. I've maxed out the Lightning 90mm sensor! LOL
Anyway, looking forward to following your build out. Have you put the FLUIDYNE radiator in yet?
If you're maxing out a LMAF its getting really close to 500 and that's ******* awesome!!
I actually haven't driven the car in a long time, but I'm ready to start messing with it again I think. I haven't messed with the radiator install yet.
Have you installed yours?
Yea, I've got it in the car. It's just what I needed for the big block. Really keeps the temps in check. I may take it to the DYNO this fall to get some numbers on it.
Get back at it! I want to see your car run. You've still got to make one of our fall meet ups at Rockingham or Fayetteville. I'd love to line the car up with yours.
Awesome man!! what did you do for a cooling fan?
Yea for sure, I don't have anything scheduled for late November so hopefully I can make it up then.
Are any other fast birds functional these days?
I kept the stock fan for the radiator. It works well enough.
I think OxmanWI, you and I are it on the LX side. There are several SC's that are tearing it up.
Rob was working on a build but I have no idea where he's at with it. He was going to build the same block I have, put lower compression pistons in it and slap a monster SC on top of it. He'll probably make over a thousand HP with it when he's done.
Hmm I don't think I have room but I could possibly trim the housing down.
Yea Robs been ******* off for a while he needs to build that thing.
Almost forgot MikeB. He just busted out an 11.280 @ 123.00
Sorry Mike!
Thanks for remembering me, Trunk! I’m making 540 RWHP with a single 340 LPH pump plus a KB Boost-a-Pump and 60 Lb injectors. I’m also using the stock fan (modified to clear the Tork Tech setup) and a Griffin two-row radiator.
Forgot to mention, I switched to MMR billet fuel rails which I think reduced restriction and contribute to higher fuel flow.
Discussion Starter #14
Nice Mike!!
How did you modify the fan? would you mind showing pictures? When I work on the car next I will be installing the fluidyne unit and I'm also trying to clear the torktech pulleys.
Are you still running the stock tank? That's my next area of concern, my current system is a modified stock hat powering two pumps individually ( E85 and 22psi or so) no clue on power.
On another note I'm trying to coordinate with trunk monkey for a track weekend this fall, if you could make it that would be pretty sweet.
bulldog,
The fan modification was simple: I just trimmed 3/4" off the "box" portion of the shroud, which allowed moving the motor away from the front of the engine. The fit is still REALLY tight between the back of the fan motor and the 8-rib pulley which attaches to the front of the vibration dampener, but they do clear. I put some strips of closed cell foam between the radiator and the forward edges of the shroud to prevent air recirculation.
Yes, my car has the stock tank.
I'm looking forward to the Midwest Bash which will include drag racing. If another event comes together, I would be interested!
Discussion Starter #16
Awesome Mike, thanks
Looking at the dates, I cant make the Midwest bash happen with work.
Did you go with a VMP blower? What size pully are you running? I may have a larger one I can send you if you're concerned with it running faster than 11.49
Yes, I have the TVS2300 blower from VMP. I’m running the 3.2” diameter pulley at present, and making 13 lbs of boost. I tried their 2.8” pulley, which made 16 psi, but the ignition didn’t seem to be able to handle that much boost. I’ve got a 3.0” pulley to try sometime later this year. My goal is to get the car into the 10’s, which of course will be way under 11.49 and I expect to get booted from the track if/when it happens.
Discussion Starter #18
Mike, If you have the octane you should be fine. What plugs are you running? Gap? Boost a spark? Your setup will definitely run 10's 9's wouldn't surprise me if you wrap it to the moon.
The car was tuned with 93 octane fuel. The plugs are NGK TR6s gapped at 0.026”, and I do have a Boost-A-Spark. With the forged internals, the engine should be safe to 7000 rpm, but it is set to shift at 6500 because the power peak is at about 6200 rpm.
Discussion Starter #20
Do you think you were having spark blow out at 16 psi? It should hold that no problem with a boost a spark and that small of a gap. are you running a COP set up or wires? Is the boost a spark turned all the way up?
1 - 20 of 27 Posts
