what is the fuel presure relief procedure for changing out a fuel filter on a 96 thunderbird 3.8L..
Start car....tap or unplug fuel cut-off switch in trunk on driver side....car will stall...pressure is now relieved. After your done push in the red button on top of cut-off.....turn key to the "on" position a few times to build pressure again....check for leaks....start car.
Chapter Director Coordinator
oh come on.. uncap the schrader valve on the fuel rail and push the release :)
make sure you have a rag over it.. 40psi of fuel soaks it pretty quick :tongue:
