Can fuel injectors be identified by color? Ones that came on my AED are red.
The ones AED sends with the kit are rated at 30lb/hr. They'e a slightly dark red, as pictured below. If you've got the injectors, it must also mean you've got the 2.5" 9psi pulley and no FMU?
Ok, i have that color red injector but my pulley is 3". Will my stock fuel pump be sufficient for this or do i need a higher psi fuel pump? The injectors on my bird now are the light brown/tan color.
You're going to either want to upgrade your pump (255lph minimum) or pick up a Kenne Bell boost-a-pump to increase your fuel suply. The 3" pully is the stock 6psi pulley. It possible that when this kit was ordered, it was put together with the Injectors and ECU tune rather than the FMU....which is the better of the two. At this point, a fuel pump upgrade and a dyno tune should get you rolling again. :thumbsup:
