As I mentioned before, I do have an occasional (but more often than not) slow starting phenomenon.
Starting takes several seconds. If I ever get so impatient that I abort the engine start, then immediately try again, the engine starts instantly.
This has led me to believe that the fuel is running back into the tank. I understand there is a check valve in the fuel pump; however, I'm not really interested in lowering the tank at this point.
Therefore my question: has anyone ever placed an additional check valve into the fuel line and if so, where exactly?
I also understand that there may be another cause entirely to this. Leaky injector maybe.
Also, if fuel runs back into the tank, does that mean air is somehow getting into the fuel line, or is the fuel just expanding back into the tank because it was under pressure in the fuel line while the engine was last running?
This is not a huge concern; the engine always starts. It's just a bit tedious, plus I'm wondering about wear on the starter.
