1 - 2 of 2 Posts
when doing any kind of PI engine swap, you need 96-97 fuel lines right?, could you not just yank out the old fuel lines, and just run your own stainless steel braided lines? wouldnt it be easier and flow better?
Boom.
I'm not sure if easier is the word I would use to describe that, but...the reason that you need new fuel lines is that the '94-95 lines will meet the new style intake manifold right where the TB is, the fuel rail accepts the lines farther back. It is not too much of a pain to switch to the '96-97 lines, didn't take us too long (the part that took the longest was waiting for the fuel filter to get there lol).
As far as flow, the '96-97 lines will support the engine just fine, if you are adding forced induction than things may change, but the stock lines should serve just fine.
1 - 2 of 2 Posts
