1 - 2 of 2 Posts
The spec for fuel pressure is:
Key on engine off 35 to 45 psi
Running at idle (vacuum on) 30 to 45 psi
Running at idle (vacuum off) 40 to 50 psi
My 94 when I tested it a few weeks ago was down at the very bottom of the range at 30 lbs. I put on a new Kirban regulator and got the pressure up to 40 lbs.
Hope this helps.
Tony
1 - 2 of 2 Posts
