noticed a slight fuel leak coming from my fuel pump area. just a drip really, underside of fuel tank on passenger side gets a lil wet and a couple small (3-4 inch diameter) puddles will form under car when car is shut off but the drip stops after car is no longer running. I'm guessing I've got a seal that's went bad but since the car just rolled over 107k i figured i may as well upgrade pumps while the tank is down. What do you guys recommend? currently my motor is a basically stock 4.6 with free flowing dual exhaust, home made intake pipe and a 75mm bbk throttle body. I'm going to be swapping a built 4.6 dohc in the next 1-2 years so would it hurt anything to go with a bigger pump so long as it is set for the same psi?? thanks, Dave
