When I start my car sometimes I get a gurgling sound for about 3-5 seconds. The fuel pump makes its normal hum when the key is turned to on then stops. I start the engine and once its running it will gurgle for a few seconds. Any ideas?
Should be easy enough to check. Have someone else turn the key while you have the trunk open and your ear close to the bottom of the trunk. As your fuel pump (unless you've modded it for an external one) is inside your gas tank, you should be able to ascertain whether or not the "noise" is eminating from there. However, I tend to agree with PHXBird that it sounds like air in your cooling system.
