I have a 2002 Mustang GT .The fuel pump wa nt come on .I installed new pump and checked before I installed and it worked .I checked fuses and they are good I checked inertia switch it has twelve volt on both wires with key on.What would you check next I can spray starting fluid in throttle body and car will start for a few seconds. Could it be theft system not letting pump come on does the theft system let the uel pumpgo on and off .Please help on what you would check next.Thanks for any help
Check voltage as close to the pump as you can get; if it's at the inertia switch, the relay is making.
What do you mean check the wires at fuel pump and see what volts I have if so do you know what color wires do you meen I have checked at inertia switch and have 12 volts on both of those wires
