has anyone done a twin fuel pump in tank set up? since i have the car apart i was going to try this but i'm not too sure after seeing in the tank. also does anyone make a pick up assembly with larger lines than stock like a -10 an supply with a -6 an return side that i can use for the twin set up? thanks wes
Chapter Director Coordinator
no.. no one makes anything for our cars
you are talking a complete custom job, and for something like that, i'd cell it in the trunk and screw the stock tank completely, run all new lines, etc
i thought about a cell in the trunk but that can be a pita for a daily driver. do you know if a mustang pick up assembly will work on our cars? i think it lock down but i wonder about the plug if it is the same wes
