Anybody doing a PI swap for a 1994-95 Thunderbird / Cougar will need a 1996-97 Thunderbird Fuel Rail. I have a 1997 Crown Vic / Mercury Marquis Rail which is better because you can keep your existing fuel lines.
The 1994-95 Thunderbird / Cougar Fuel Lines hook to the fuel rail in the center on the passenger side. The 1996-97 Thunderbird / Cougar Fuel Lines hook to the fuel rail in the rear corner on the passenger side which is why you have to change to the 1996-97 Fuel Lines if you use a 1996-97 Thunderbird / Cougar Fuel Rail.
The 1996-97 Crown Vic / Mercury Marquis have the same fuel rail with the connectors on the driver's side. However, if you turn the rail around, it is identical to the 1996-97 Thunderbird / Cougar rail except the inlets are in the center which is what us 1994-95 Thunderbird / Cougar guys need.
So, I have 1997 Crown Vic / Marquis rail that you can use and keep your existing fuel lines for the PI intake swap - $20 plus shipping.
I also have a 1996-97 Fuel Rail that the lines were cut so it will need to have new lines installed - $10 plus shipping
Discussion Starter #2
ttt
PM sent
PM replied to, sale pending...
