1 - 17 of 17 Posts
Hi everyone,
A friend at work has a low-mileage turbo that they are willing to part with cheap, as they haven't used it for some years and have no plans on using it.
It was on a stock engine, they ran it for a while but took it off before they blew the engine up. (It was on a Prelude, for what it matters).
They did tell me it needs the exhaust plate (I just said okay, being uneducated on these).
So anyhow, this would NOT be for my 4.6, but for my Chevy small block (350).
They want 200 for it.
My questions are this.
A) is this a good deal? (assuming it doesn't need to be rebuilt, but given it was running for only a short time on a stock car, I imagine it's in good shape).
B) where can I find some specific info on this (like with that exhaust plate?)
C) any other tips would be helpful!!
Thanks!
Too much in my opinion. Look on ebay and you get a newer, better turbo cheaper or for around the same price..
As for the plate, you need the specific model of the turbo and research it on ebay or google. Just read teh title again and if it's a T70, look for it on ebay, you will find what you need there.
Thanks for the reply TX, could you give me some links or something I can read on turbo basics. I understand that there's a "balance" on what size/flow a turbo should be to optimize it's use with an engine.
And if it's not too much to ask, when you said "better", how so? Can you setup any comparisons between the two for me?
Lastly, I guess that prices in turbos have fallen quite a bit? I was told that they spent over 800 on it when they got it new? I don't have any reason to doubt this person, as they weren't looking to sell it, just came up in conversation.
Thanks!
Thats a good deal if its in good condition you couldnt get a master power T-70(brazilian garret knock off for less than 600. The garret T70 go for around 1000$+ new. Just do you research on the turbocharger and check for ply...in and out and side to side play. a little side to side play is good and normal in and out play is bad and is usually bad thrust seals. You may need to purchase a different exhaust housing for the larger motor. If a brand new turbocharger is going on ebay for only 200$ you can be sure its a chinajunk built turbo that sometimes have horrible castings, wrong dimensions, and poor quality materials.....
There are different trims for the T70 so do you research on the specific models
Hey guys,
Thanks for the posts! For some reason I didn't get an email telling me there were any updates... I happened to check back just on a whim. Glad I did!
TX - thank you very much for the link!
TT281 - You are very close to what they said they originally paid for it. When you say "side to side play" do you mean if I were to try to "rock" the blades on their spindle, or literally shove it side to side, moving the spindle with it?
Unless they forgot to bring it, I'll be getting it today, and I'll post up everything that's stamped on the outside of the thing - the information I originally posted is what they told me it was (Garrett T-70 AR 50).
Thanks again!
Hey guys,
Thanks again!
Strongly suggest you get all the info on the turbo and make sure it's a good match for the motor you are planning to use it with, before buying.
David
I plan on doing so, the hard part is finding some definitive information to do just that. I've tried searching for variations on the information I have (stated in previous post), but haven't found anything.
What would be stamped on the turbo somewhere that'll give me more information to search with AND where would I go to find out if this is a good match up for my engine?
Thanks!
Thanks!
Go here and post your questions in Newbie Tech.
http://www.theturboforums.com/smf/index.php
Stuff like exhaust housing type..T3 or T4 on center or tangial, AR and outlet diameter along with compresser inlet and outlet diameters along with any info on the ID tag of the turbo will be helpful to ID exactly what turbo it is. Photos of the turbo will also be helpful.
David
Thanks David!
As soon as I get the pics taken I'll go ahead and hit that link and post up all the requested info.
Ditto on what David said. Even with my turbo all apart and measured, it took Preston and I quite a while to figure out specifically what it was. STS didn't have or couldn't find specific record of what they sold me. (no surprise there) :D
Alright guys, I'm waiting for thetubroforums to get me my account activation, so while I'm waiting on that, I figured I'd post some links to pictures I took (I apologize for the quality, if anyone needs better pictures of anything, let me know and I'll borrow ShadowDragons camera).
Also here is all the info stamped on the outside of the thing and where.
On the turbine housing - M12 Garrett A/5 50 1
On a plate mounted on the secontion connecting the
turbine housing to the compressor housing - 700382-5020 IDM022247
On the compressor housing - Garrett .86 T712
Let me know what you guys think! The blades spin very well, and have no "play" in them at all.
Discussion Starter #14 (Edited)
Thank you so much! I could not find the model on the site for the life of me, but I was typing in the whole thing in my search, 700382-5020, which is probably why I was getting no results!
Now at least I know I need to move on to something bigger...
Thankfully I had started reading up on Garretts site, and I think this is the one I'll want to go with - GT4088R 751470-1 , but it's "free float", so I'll need to get an aftermarket wastegate, and it's oil & water cooled... now I know what the oil cooled part means, but the water cooled - does that mean it'll be piped into my radiator as well? Or is there were the intercooler stuff comes in?
Thanks again for tracking down the info!
*edit* I just noticed that with the next few models on the site, the 751470-2 -3 and -4 the only difference in them is the Turbine A/R, going from .85 to 1.19. How does that impact the performance of the unit?
yes water cooled means water is also pumped thru the center section from the cooling system
Discussion Starter #16
Hey TT,
Thanks for the info. Sorry to bug you with more questions, but with the watercooled, does that mean it has it's own seperate watercooling system with the use of the intercooler? or is it piped into the radiator somehow?
Any thoughts on my question about the various models of Garretts? with the A/R size and such? I thought it was odd because the listing was still showing the same range of horsepower.
And I'm not just trying to pester you guys, I'm running stuff by guys on the theturboforums, but another perspective or more information rarely hurts.
The watercooling to the turbocharger is plumbed thru the motors coolling system. Some plumb it thru T fittings in the heaters hoses or other collant ports on the head, or intake.
The intercooler your thinking of is a air to water intercooler which uses its own cooling circuit not engine coolant.
As far as the turbopcharger goes it has alot to do with CFM that a turbocharger can flow. Without even running the maps Its obvious that you would need two of those turbochargers as page I linked above says displacement of 1.8-3.0L, You of course have a 5.7L 350ci V8. The Gt30 also has a T-25 turbine housing which is a turbine housing that is ran on many oem 4cyl setups. If you only had on of these it would be overspinning the unit to make boost and the turbine housing will be choking the motor out with that t-25 housing. two of those woudl work but Im willing to bet you can fidn a better pair or single turbo that will do the job. Take your time to search theturboforums to see what the other SBC guys are running.
1 - 17 of 17 Posts
