I bought all the parts and such for the J-mod on my 95 tranny will the valve body gaskets work on a 2000 trans?
Also, When looking through the tech article it's kind of vague about what to do with the 99+ tranny's.
Is everything still the same other than the holes in the separator plate that have already been modified by FORD?
I realize the accumulators would not need to be updated and the springs would be deleted, but what else?
Thanks
They should be the same... just be sure when you pull the separator plate off, hold the gasket up and make sure all the holes in the gasket are big enough, you might have to enlarge one or two of them.
So I have to buy 2000 gaskets?
Cougar Pilot
I certainly was under the impression that I had to. The '99+ valve body IS different, but I suppose that doesn't mean the holes in the seperator plate are in different locations. Some holes that I enlarged on the '94 VB didn't need enlarging on the '00 VB. VB gaskets should cost less than $5 anyway.
