5w30 Guzzler
ive seen a bunch of jmod parts lists posted and many of them do not include these gaskets and many of them do. are they absolutely required? im ordering the parts today so a speedy response would be greatly appreciated and thank you for any help.
F2VY-7C155-A Gasket
F5AZ-7D100-A Gasket
chilipepprflea I posted a minimal parts list for you on your post :
minimal jmod parts list below on 08/18/2003.
Fuel man~~~ Yes, those are the v-body gaskets you need.
I've re-used valve body gaskets, but when they've been cooked in there for a long time they get brittle and you don't get them out in one piece.
The downside to new gaskets is the 8+ hour and 2-week re-torque you should do as they compress.
buy new gaskets, and use a torque wrench on the valve body bolts. They are not reusable as far as i'm concerned. They get brittle and rip easially if you try to reuse them.
i highly recommend using the proper sequence and going over the bolts 3 times. check my article in WIP for the picture if you need it. Doing it this way i've never had to retorque my VB bolts and never had any problems.
