Status
Not open for further replies.
1 - 20 of 47 Posts
Hey guys, my borther and I want to both do a gear swap in our cars, his is a 95 GT Mustang with a 5-speed, and 3:55 Trak-Lok Gears I believe. He wants to to put in 3:73's or 4:10's. My car is a 97 4.6 T-Bird with an open 3:27. I would like to put on 3:73's or 4:10s also. How much would it cost my brother to get the gears and have them installed? How much would it cost me to have TL rear end installed? Thanks for any help.
If you supply all the parts I would say 250-350 for a full rebuild and proper installation of the gears. Setting the gears up correctly is important don't let just anybody set them up, the process takes time you just have to be patient.
Alan
Discussion Starter · #3 ·
Wow, I thought it'd be a lot more than that. That's just for gears you mean right? Also, is it cheaper to do the swap on A solid rear like a mustang than on an I.R.S. car like the MN-12's?
Sounds like he means $250-350 for the labor. I assume that would be if you take the carriers down to a shop vs. taking the whole car in, maybe not though
IRS and solid rear shouldn't matter if you take in the carriers.
Probably be around $200-300 for parts depending on what all you need, and what brand of gears you get. Also the t/l will add to that for your car.
I got brand new Ford 4.10s for $120 shipped, and I'll be picking up a used IRS TL unit for $55 soon. You can get the gears and TL carrier for pretty cheap if you shop around.
i have about 220 dollars in gears and trac-loc, and a local shop is going to do the install for about 100-150 dollars. i am suppling them with the pumpkin and parts.
Discussion Starter · #7 ·
Wow, I thought it'd be a lot more than that for some reason, maybe this is still in the works for the Tbird, drifting sure would be much easier with a 3:73 TL.
Only you can prevent modular fires
"Slomo" "I got brand new Ford 4.10s for $120 shipped, and I'll be picking up a used IRS TL unit for $55 soon. You can get the gears and TL carrier for pretty cheap if you shop around."
The 8.8s dont have to be from a IRS All LSD's work from 8.8s Or I should say all 28 spline
gears rule, you are going to love them, money well spent!!!
Formerly Fdawg97LX
yes the mustang has an 8.8. and my recommendation for both of you is to screw the 3.73's and get 4.10's, you definitly will not regret it. i paid $350 for install of gears, rebuilt my stock tracion lock, heavey duty u-joints, 23 tooth speedometer gear, steeda irs bushings and all fluids. That includes them pulling and re-installing my pumpkin. i brought all the parts and just dropped my car off and picked it up the next day with all of it installed. 4.10's are best upgrade i've done so far for everyday driving. makes the car so much more fun to drive. i was quoted by the same shop $200 to swap in the gears and rebuild my stock trac lock if i pulled the pumpkin and droped it off there but i had them do it all.
Frank
Let me put it this way. If you brought me the whole car and all of the parts i would do it for $350. If you brought me a pumpkin I would do it for $250. Swapping the pumpkin isn't very difficult. Setting up the gears properly is(can be). I'm sure it is easier for Teeps because he seems to be the rearend man around here. My recomendation for anyone who is not going to do them yourself would be to pm Teeps first. I can't think of a shop around I would want to set up gears on an 8.8 for me. Anybody who says they'll do it for $100 is either underestimating the job because they have never done it before, has done it before but really doesn't take the time to get it right, or likes to work for $5-$10 an hour.
Alan
Yeah, I agree you can spend alot of time if your being really accurate with the gear clearances, which I am.
Dirty Dog hit the nail on the head.
If you have the right process down, you can come pretty darn close on the first shot, or two, with really good tools, careful math and very accurate measurements (you'd have to be a robot). This takes quite a bit of time in itself.
However, it is much easier said than done, usually will take quite a bit of prep, and re-prep to ge everything just right. I build everyone one of these like it's going into my own car.
Lets just say, I've seen some pretty sloppy stuff come out of gear shops. Yet people drive down the road with a whiny rear end, and don't realize it until quite a few miles down the road during a highway trip, when they finally turned the radio down low enough to hear it, lol. I've seen gear shops turn people away, that came back correct this, or offer to check it but only if the customer pays the same flat rate again to tear it open again.
I'm doing them at a low price right now, just to show that my setups will be perfect, and take a real licking. (especially if you opt for a detroit locker).
I'd rather get them out there, and let people field test and abuse them, I back anything I build, and I'm happy to prove my builds first at a lower price.
But I'm still assessing a good average time for this job, and I won't always be doing them for as cheap as I'm bidding them now. Because all I do are 8.8's nothing else, and I do them to NASA clearances.
You won't get that outside of a really good Ford speedshop, and your not going to pay less than 350-500 for one of those shops to do it the right way. Maybe even more, many of those shops charge alteast $100/hour
So right now, if you provide all of the parts, and a new carrier, I'm only charging $120.00 to rebuild them, this is for about 6 more months. Then I will reset this fee to a larger amount, based on average time. I'm guessing I will charge at least double this price in the future, but I'm going to average this after several jobs.
If you are providing a carrier and housing, and gears. In a high mileage unit, everything needs to be rebuilt, I replace every single bearing, bolt, race in the entire unit, including the side/pilot bearings for the half shafts,
(Unlike gear shops, I'm not going to send one out with new carrier bearings, and 100,000 mile pilot bearings.) It will cost $30.00 labor for me to rebuild the carrier (for the next 6 months) if you send a new traction lock carrier or other, and don't need any build up done, then there is no additional labor for my installation of the carrier.
The parts and supplies alone for the entire pumpkin (minus the case/gears/carrier)
cost in the range of $200-250 (thats for minimum, no custom options). add 150-185 for gears, 75-150 for a case, 75-500 for a carrier (from used OEM, to wild aftermarket), and add for any custome options, e.g. one piece spacers, carbon fiber clutches, solid spacers, hd shims, re-usable gaskets, etc, etc.
Some additional options may include custom machining if the carrier used does not have grooves for circlips (if required by customer) on the side gears (for half shafts - retention), does not include 28 spline side gears, if a 31 spline carrier was provided.
I have hunted around quite a bit and the cheapest I've found a shop doing this work, was doing it to beat the local competitions price, Local competition was doing it for 200, and this shop was beating them by 20-25 bux I can't remember exactly.
They did work mostly on chevy, and dana rears, and knew very little about 8.8 IRS or specifics of Aluminum differentials.
There are special specifications for Aluminum diff's that are complete different from iron 8.8's, never mind Dana rear ends.
I asked one of them there about bearing kits for the 8.8 IRS, and he was adament that the kit that included axle bearings for a live axle setup would work fine with the IRS diff, which is totally incorrect.
Obviously, they would have charged the customer for these, reliased they wouldn't work, and left the old ones in, and sent the customer on their way.
I trust those guys to work on one of my 8.8's about as far as I can through a cast iron one.
Just my .02
It pays to work with people who have worked on a specific application and have real world results with that application. Or a Niche-professional.
I know who I'll be hollerin at come time to get a new converter,
The guy that knows the application, and the converters in and out. DirtyDog!
For any parties interested, I'm building up a detroit locker for an Aluminum diff, with 4.30's for a customer, and he's got a pretty darn powerful test bed, so he is going to poor the heat on this sucker, and see how much of a lick'n it will take.
I'll probably be installing it towards the end of February.
I'm sure he'll be reporting back with his findings sometime in the spring.
Don
  • Like
Reactions: dirtyd0g
Discussion Starter · #14 ·
My car is a TL, do I need anything else for the install except for a new gasket, rear end fluid, a new speedo gear, and a chip reburn?
Install what?
Short answer is YES
edit: Just looked at your first post.
Most guys go through the whole rear, and look at the bearings and races, if they look bad then they replace.
Personally, If I know there has been more than a few miles on things, and any of the bearings in the rear look worn, then I replace every single bearing/race, after first completely cleaning everything out. Lotso break cleaner to buy.
New pinion and carrier bearings are a minimum, you'll need shims, bolts, and I recommend you rebuild the TL while your in there.
In which case you'll need a rebuild kit for the T-lock (personally I usually add extra clutches at minimum, depending on the clearances I might also add a stiffer S spring)
New gears come with a new crush sleave, and there is so much more to this. I'm not going to post a how to on here, there are a few articles out there.
I think I had about 400-450 total with mine, bought a used SC center section (ended up being about $150 ish with shipping on it, shipping raped me there), New 4.10 gears ($180ish?), trac loc clutch rebuild kit ($50), new bearings, install and gear oil. Dependng on what it cost to get them set up and what you pay for a trac loc carrier you could end up with as much as $700 in parts and labor based on a quote I got from one shop in omaha. I ended up with a hook up on someone who would set teh gears up for me.
Fry Rice Specialist
teeps, how much you're gonna build one if you supply all the parts? my car couldn't afford any downtime hence that's why i want a complete dropin pumpkin. i want a trakloc 3.73 aluminium pumpkin. iron case also doesn't matter but alumimium prefreable just for the bling factor.
I got my FRPP pumpkin w/ 3.73's and a LSD for about $650 shipped from MAx at 5 star ford. I went that route because it was the cheapest, and I sold my original center section for about $150, so about $500 for a completely new set up, not too bad. :headbang:
Case 75 iron
150 aluminum
Price varies on the trac lock, especially if you want the extra clutch packs and rebuilt, I'll try to find a used one since it's going to be rebuilt, and the older units are better.
If you just want a new TL they run in the 180-190 range + shipping.
On average TL range from 80-190 .
120 for build up labor flat rate, 30 for TL build up if needed, hourly for extra mods.
parts for minimum install = $330 +/-
so case + 120 labor + 300.00 parts + new TL 210
If iron then it woud be 75 + 120 + 300 + 210 = 705 + shipping
or adjust the TL pricing above for a used unit in good condition if that's what you want. So 210 becomes 120 (avg price) and total changes to $615 + shipping.
If you want a stouter trac lock with extra clutck packs, etc
then with iron case: 75 + 150 + 330 + 120 (average used TL)
$675 + shipping
If you want custom options, it will cost more.
Alow for parts price changes, that $330.00 may fluctuate based on current parts pricing, so alow atleast $350.00 in your budget.
Also you can substitute a different differential like True-Trac or Detroit Locker, or Torsen, etc.
You can then delete the TL pricing, and insert pricing for the diff of your choice.
Hope this helps,
Don
What have you seen to be the average price to ship an assembled pumpkin? Also do you ship it with the fluid in it?
1 - 20 of 47 Posts
Status
