Hi,my 8.8 is reddy for pick up,im just not shure wich oil to use ,is a 8.8 whit new Torson .Tx for reply.
MAIC
MAIC
With a stock trak-Loc - I use Mobil 1 75w-90
I would ask the shop guy what to use for a Torson ?
Stolen from http://www.torsen.com/fsae/fsaefaqframes.htm
8. What should I use for lubrication?
A GL-4 or GL-5 gear oil is required by Torsen Type 1 units. This oil provides high-pressure additives needed to prevent the oil from breaking down under the extreme conditions generated by the tooth mesh. A 75W-90 is recommended, but higher or lower viscosities can be used if they meet GL-4 or GL-5 specification. Either synthetic or conventional oils can be used as well.
I seem to remember some production vehicle that came with a torsen and they kept exploding..hopefully thats fixed. Good luck with yours.
Got it !!!!!!!!!!!
Tx a lot ...... MAIC
I used the ford synthetic gear oil with the friction modifier.
