1 - 12 of 12 Posts
ok guys i just gears for my car there richmond gears 3.73 the guy from jegs said it would work for my car, but i looked at the pinion gear and it alot bigger than the stack pinion it looks more like a ford 9 inch pinion do u think this will work out i was told if the pinion bearing fits it should work. and i was also wondering what spline the pinion is it a 30 spline pinion? thats what i have
is the gear set for an 8.8 ford? splines matter for your differential, not your gears.
yes there for an 8.8
the guy at jegs said they'd work for my year of car i told him that i had an irs rear and he didn't know they did
i was just wondering cause the stock pinion gear is really small thats all i geuss i'll know alittle more when i get the rearend apart
you really dont plan on installing those gears yourself, do you?
i was planning it but i heard it can be a pain so i thinking about taking it to a shop to get it done
as far as size goes there will be a differance in the size of both ring and pinion depending on what gear ratio you use. you will also notice a differance in the angle of the teeh of the ring gear
1 - 12 of 12 Posts
