1 - 11 of 11 Posts
i was wondering if i wanted to change my gear ratio to 3.73 or 3.55 is there anything i should do or be aware of. I've honestly never done this before and im just looking for tips
Thanks!
Thanks!
Your stock gears are 3.27, so going to either of those is not a problem.
Two issues:
1) You will have to change your speedo gear or your speedometer will be off.
2) If you don't have a chip/tune, your max speed will drop. ie, if your speed limiter cut in at 104 with the 3.27, it will cut in at about 98 with 3.55 and 93 with 3.73's.
I started with 3.08's in the rear and swapped out to 3.27's and my max speed went from 104 to 98 since I don't have a tune yet.
Have it done professionally.
+1 I kind of "assumed" he wasn't going to do it himself...
Ok, I thought you were going to try them on your own! :eek:
Do it up Dad! :D
also if i do 3.73 how much will it effect my tranny? Will it hit the rev limiter at wot? If so what can i do to get rip of this, im asumming a tune but id like to avoid that because of my budget
I have my 21 tooth speedo gear for 3.73 gears. Do i still require a tune. If my top speed is going to be around 150km/h im cool with that. my speed limiter kicks in at 160km/h i believe but i hardly take it up to that speed. Can i buy a tuner and change the limiter myself? I think im willing to buy one now because I also did the PI Intake Swap.
Yes, SCT is the preferred solution on this board. They will help you with the tune for your car and yes, it will remove/raise the speed limiter. I haven't done it yet, so I'm sure someone with more experience will help you shortly.
1 - 11 of 11 Posts
