1 - 2 of 2 Posts
I have a complete IRS center section from an Explorer with 3.73 gears and a posi unit. It was taken out due to noise. It was free so I checked it out. Will this swap directly in, or will I have to remove the gears to use them? Thanks in advance, Scott
The only parts that will swap over to the T-Bird IRS are the ring & pinion. The traction lok (posi unit) will swap, but you'd have to convert it to 28 spline for it to be useable.
1 - 2 of 2 Posts
