I need to replace my glove box because the lock broke off from the panel it was attached to, leaving my light on all the time and the box open a bit.
According to the local dealership i can get away with replacing just the three outer panels on the door itself, because that's where the lock broke off from.
They want $180 for those three outer panels that they say i'll need. Do i really need all 3, or can i get away with the innermost one? If i go to a junkyard, could i use an intact 94 and up box, or just 96-97? They look the same to me, but I'm not totally sure.
Same thing is wrong with mine, I shoved a pen in there to keep the latch secured to the outer door.
The outer door is what you need, it's what the latch screws into.
Re: Re: Re: Glove Box...
Zephyr said:
can i use the parts from a 94 and up though? or just 96-97?
I know they removed the lock in the 97 model, not sure about the 96. Do you have a picture of what yours looks like closed?
I would think they just didn't put a lock on the latch and used the same trim though.
94-97...
They are all the same.I have a 95 that I painted Black and it looks the same as my 96.I never noticed about the lock thing on the 97 though.I know my key wont fit in the one I have from the salvage yard but it will work on my 96 though.So I guess I will be changing my lock on the one I painted.
Chris
