I think my idle might be low but im not sure Ford couldnt tell me what its supposed to be could some one with the 4.6 put it in gear and tell me what the idle is so i can compare to mine? I'm at 500ish rpm. Thanks :confused:
900 rpm idle in park/neutral
550 rpm in any gear while non moving
keep in mind the stock tach isn't perfect/great, so it may read a little off, my 4.6 at idle in park will appear to be 640ish, but when you hook up some diag. gear it will say it's at 550ish.
500 isn't bad, unless it's making wierd noise, jumping around, or causing a vibration
Fry Rice Specialist
check the tps sonsor. the middle one is positive and the bottom wire is negative. should set it between 0.980 v to 1.020 volts.
Thanks all
Thank you every one! well my in gear idle is about good then however... my park neutral idle is just the same. my motor does vibrate a bit when in gear and sitting sitting still but i get no mil or cel and im not getting any DTC's im wondering if i turn the stop stid on the t-body out just a tad if that would help, i haven't monkeyed with it yet so i dont know if thats advisable>
Fry Rice Specialist
don't turn the screw. check the tps sensor first.
