not bad... I've seen more detailed write ups though
seems pretty simple if you look at it logically, assuming there is no danger of bent valves(the pistons are down), mark the 2 endpoints of the chain and install it so the marks meet the marks on the cam and crank gear.
^^^^ Yup, I remember an article where simply degreeing the cams on a 2v gained somewhere near 10-12 hp. They were off 3* each bank IIRC.
