got a code today 174 book says the oxy sensor switching slow? WTF? which one? anyone encountered this? thanks for youe help. by the way its a 4.6 auto it has 2 sensors.
The Band, not the Disease!
Clean your MAF wires. There's a tech article on it, go to the main TCCOA page and hit tech articles. You actually have 4 oxygen sensors, the 2 primaries (the front 2) and the other 2 just tell the CPU the cat's are working. Try taking them out and heating the tip up with a torch and clean them up a little. How many miles on the car???
i already cleaned the maf wires and flashed the computer. the ck engine light turned back on and the code 174 was . i know there are 4 ox sensors but only 2 per side! but i did not know what the rear sensore read! thanks. so i'm assuming its the front oxy sensors?
do a search on this code theres tons of threads and suggestions on what to look for. This code is pretty common around here.
one book says lean on right side another is oxy sensor is switching slow. but which one is bad the front or rear?
It will be your front one. If its bank 2 i believe its the passenger side upstream 02 the one closest to the engine. Do a search because i just did one and this code could be a number of things. Check those first b4 you haul out $80 for a new sensor. Just a suggestion
-Matt-
