ok my mother in law has a 98 ford explorer 4.0. It was wrecked a few months ago, the body was damaged and the radiator needed to be replaced. Well now it is vibrating from when it is turned on and while i drive. There is blue/white smoke coming out the exhaust and there is oil on the tip of the muffler. I've been told it could be the cats before the oil was noticed and now we're are being told it could be the rings. Does anyone know what could be wrong. All your help is appreciated :uppoint:
Thanks
sa t-bird
go to the forums over at www.explorer4x4.com
it's a good, informative site for explorers and they should be able to help you out
Thanks I'll check it out. Last night i pulled the plugs out to check them and one had oil on it . I didn't have my compression tester with me so I'm going to do that today. Iassume it's the valves. Thanks alot!!:D
