Cougar Pilot
Apparently the tie-rods are screwed all the way in?
I installed them myself from RockAuto (Moog) and they figured that I used the wrong parts, I would be surprised though. I asked what the solution to this was, I was told that they can always pull them off and cut them down.
I'm thinking there's a setting they missed or something else. I was told it's aligned for now but there's no more adjustment for the future.
Any ideas?
I don't see how that would be possible unless it was the wrong parts but i'm no alignment guy so I could be wrong.
Some rebuilt racks have come with Mustang inner tie rods, that are longer than the MN12 ones, yielding this exact same situation.
Wouldn't surprise me if that was the situation.
And cutting them off is the easy, cheap and obvious fix.
Before you take it in next time, borrow a small angle grinder {though any driveway mechanic should already have one - VERY HANDY} buy a cutting disc for it.
Spray paint the thread/ lock nut area, unscrew the outers and cut about an inch off each side. You are removing threads you never will use.
