im having a groan noise coming for the rear of the car. as your getting up in speed you can hear it more and when you come to a stop you can hear it the best. the sound gets faster as you speed up and slower as you slow down. any ideas
Keep it simple, check for any abnormal wear patterns on the tires and for proper suspension geometry/alignment specs. There's also the possibility the sound is coming from the differential or wheel bearings. If you rotate the tires (front to back on the same side) does the sound follow the tires? How long has it been happening? How long have you had the tires?
the tires are new (nitto 555) but it just started probably a week ago im gonna jack it up tomorrow figure I would ask first to make sure im looking in the right spot
