So I messed around a little with how I'm going to mount the GT intake assembly (air box + intake tube etc.) today and have a few options for how I want to do it, I'm just not sure which option is best.
1) I have the rubber boot that attaches to the opening in the air box, which I found works well if I run it through the existing hole in the engine bay to hold the air box in its place without my having to secure it with screws or straps. If I decide to go that route though, I'd have to cut off the bottom half of the boot so airflow isn't restricted by the inner fender lining.
2) I can leave the rubber boot off and simply let the air box rest naturally in its place, held in place only by the rigidity of the intake tube.
3) Similar to #2, but I'd find a way to secure the air box with a strap or something.
With all the above options I'd be leaving the area under the fenderwell open to the hole in the bottom of the air box; IE, no air silencer assembly or other tubes. Will there be any problems with that?
