The seal on my half shafts right at the pumpkin are leaking.
I know I need to remove the nut near the wheel.
Someone said that you just "pry" the halfshaft out of the pumpkin? Is there a c-clip or similar holding it in? If so do you have to remove the diff cover and remove the c-clip? Or have the cover off when you put it back in so you can reattach the c-clip?
Mine is a 97 t-bird, 7.5 inch rear end, non posi....
Thanks
Thanks
