when changing out my rear controll arm bushings,my neighbor was helping and let the impact slip and punctured a small hole in the inboard cv boot,i have decided to just change the boot.after some reading it was stated to change the circlip on the halfshaft,anyone know who would have just this clip?
There are folks running without the circlip -it's there to hold the half shaft in place, but it's under compression ANYWAY.
Or you can reuse the old one.
Swapped HS a few times never bothered with the C clips at all you should be ok and yes I read the same thing. The dealership parts guy said not to even bother with it.
