I have a 1991 T-bird 6 cylinder. Its does not want to start and this happens when cold or warmed up. Once it starts it runs great. However, I decided to do the following:
1. replaced spark plugs with Motorcraft copper plugs.
2. replaced cap and rotor.
3. replaced spark plug wires.
4. replaced battery
The car cranks fine but it takes 3, 4, or 5 times cranking before it starts.
Again, once it starts the car runs great.
Any idea what the problem could be? I am a novice when it comes to car repairs and hopefully it will be something I can do.
Thanks in advance.
Larry
Other maintenance I don't see
1) Clean MAF
2) New air filter
3) Check IAC, replace if necessary
4) Since it's a 1991, it's not as easy as a 96/97 (or 94/95 V6), but a log of what the ECM is doing while you start would be nice, I'm sure.
The non-EDIS 3.8s don't have a crank sensor.
As to the OP's problem... have you verified spark while cranking? And have you checked fuel pressure at the fuel rail?
Pull the vac line into the Fuel PRessure Regulator and check for fuel. Common fail.
Cycle pump with key on several times. Symptoms better, or worse?
Floor gas pedal while cranking. Symptoms better, or worse?
Thanks guys for all the great responses. I hope to work on the car next weekend and hopefully the car won't breakdown before that.
Larry
