1 - 1 of 1 Posts
I saw this video and followed the tutorial to harden FireFox. In addition to running NoScript, Ghostery and HTTPS Everywhere (As recommended by Grog) I thought these changes were worth mentioning.
Plugins:
uBlock Origin (Raymond Hill)
Privacy Badger
HTTPS Everywhere
Options:
New Windows and Tabs should be blank to prevent a site from knowing the pages and tabs you open
(Privacy and Security)
Do not save passwords and autofill
Do Not store history
Do not allow 3rd party cookies (only use first party)
Do not allow search suggestions in search bar
Block Popups
Warn when installing addons
Do not share telemetry with firefox
Do not use Firefox Account
about:config
WebRTC is DRM, allows netflix, and others, but can show real IP if you are on a VPN
media.peerconnection.enabled
Fingerprint resistance - why is this not enabled by defaults?!?!
privacy.resistfingerprinting
(set to true)
Disable 3DES Cipher - many security vuln and is depriciated
security.ssl3.rsa_des_ede3_sha
Safe negotiating requires only the safest negotiation with servers
security.ssl.require_safe_negotiation
(Set to True)
Disable TLS version 1.0 and 1.1
security.tls.version.min
(enter value 3)
Disabling Automatic Form Filling (extra step to not remembering history)
browser.formfill.enable
(set to false)
Disable Geolocation
geo.enabled
(set to false)
privacy.resist.fingerprint
Deault is False
Set to True
Security.ssl3.rsa_des_ede3_sha
Default is True
Set to False
security.ssl.require_safe_negotiationn
Default is False
Set to True
security.tls.ver
Set security.tls.ver.min from 1 to 3 to prevent using older versions.
Default is True
Set to False
Geo.enable
Default is True
Set to False
browser.newtabpage.activity-stream.feeds.telemetry
Default is True
Set to false
Disable all telemetry - there are a lot of these, they are all under toolkit.telemetry
browser.newtabpage.activity-stream.feeds.telemetry browser.newtabpage.activity-stream.telemetry
browser.ping-centre.telemetry
devtools.onboarding.telemetry.logged
toolkit.telemetry.archive.enabled
toolkit.telemetry.bhrping.enabled
toolkit.telemetry.firstshutdownping.enabled
toolkit.telemetry.hybridcontent.enabled
toolkit.telemetry.newProfilePing.enabled
toolkit.telemetry.unified
toolkit.telemetry.updateping.enabled
toolkit.telemetry.shutdownpingsender.enabled
Disable Prefetching - firefox will preload links you might click on, thus using more bandwidth and calling content you have not requested.
network.dns.disableprefetch
(set to true)
network.prefetch-next
(set to false)
Disable all notifications
dom.webnotifications.enabled
(set to false)
network.http.sendRefererHeader
Default is 2, To not send Referral set to 0 for better privacy.
1 - 1 of 1 Posts
