Does anyone know what the weight of the stock balancer and crank pulley assembly is on a '95 4.6? I have a set of U/D pullies from FRPP and it's the non-piggyback style crank pulley. The U/D pulley weighs in at 29.6 oz., or 1.85 lbs. I was told it would work on the bird, but just want to verify.
Thanks in advance
Jay
These are for a 96-98 Mustang GT, and I was wrong, it is the piggyback-style pulleys. The guy I got them from said I'll have to re-use my stock balancer. Sounds like they'll work. Thanks for the info. Just wanted to double-check before I hassle with it and find out it doesn't fit. Only plan on yanking the crank pulley once, and that's all.
SanDiegoLXBird said:
Whatever you do, don't forget the sylicon gasket maker, (RTV, I think) That is, unless you /want/ a huge oil leak in the crank pulley keyway.
yeah, RTV, i used High Temp black.
joseph
