· Confirmed V6 Nut
Does anyone here have EXPERIENCE with the single port to Splitport head swap? Is there a problem using my 97's shortie headers with 97 F-150 heads?
· Registered
I did it.
The newer style headers didn't line up with the older style downtubes, so I ended up using the cast manifolds.
I did notice that you will have to use the TBird exhaust gasket. The one that came with the F-150 top end was smaller then the header ports.
Of course the egr will have to be deleted or rerouted.
Hopefully this is some help!!
Good Luck!
· The Parts Guy
Nope, they'll bolt right up. :thumbsup:
-Rod
· Confirmed V6 Nut
Discussion Starter · #4 ·
Rod,
Advance Auto strikes again. My buddy who still works there said that the mainfold gaskets were way different according to the information he has at work to research with.
· The Parts Guy
PCD said:
Rod,
That's correct, as the ports are shaped differently. However, the MN12 manifolds will indeed bolt right up to the splitport heads. I know what I have on my own car.
-Rod
