1 - 12 of 12 Posts
After a huge fiasco getting exhaust work done, I had iterated to my girlfriend's mechanic that the tbird has a 2-1-2 setup and there is nothing to be gained from that second muffler/tailpipe and he should just delete the y at the tailpipes and have a single pipe running to a single muffler. He didnt listen and it cost us extra money.
Is there any advantage to 2-1-2? Is that second exhuast path really helping anything?
The reason I am asking is that guy welded it wrong and use cheap crap pipe for the centersection so its stainless steel->rusty pipe->stainless steel. I was thinking of lopping the entire passenger side of the Y off and welding the opening closed and save a few pounds in the process.
Will I lose any hp or is 1 tailpipe adequate? I would think the real restriction is in the center section.
Thanks for your thoughts guys!
Pete
I'm guessing the extra bend and the Y-pipe is enough to cancel out any flow gains from an extra muffler, so performance wise it wouldn't make a difference but you'd get to loose some weight which is always good.
My thoughts exactly.....
I wanted to see if anyone has actually tried it or if there would be a "dont do it man, you'll choke off the motor!" reaction...
Well, that one leg at the rear would only 2.25, not 2.5 like the center section, right? 2.25 from each header->y pipe->2.5->split to 2.25 at rear. If it was 2.5 all the way back, it would be better, I wouldn't get rid of one side at the rear if it is 2.25.
I didnt realize the center pipe was 2.5...
Well, now I'm torn between weight loss and exhaust restriction.
I thought the same thing but I found out that its actually 2" from the the exhaust manifold and then I'm a little confused about the rest. Anyone wanna set the record straight?
It's 2" off the manifolds, through the cats to the resonator or 3rd cat. Then it's 2.25" back to the Y and 2" (or 2.25") to each muffler. There is no 2.5" stock on any of our cars.
I have 2" into 2.25" into 2.5" into my rotating muffler then 3" out the back. :D
Well, in that case, a small patch pipe running from the 2 1/4 inch end directly to the flowmaster inlet would accomplish the same as what we have right now.
It might have less escape path but the pipe would be straighter. ..
I crawled under my 97 to measure, and it APPEARS that I have 2.25 to cats, 2.25 off Y to back, tail pipes after they split seemed to be 2 inch, but no real good place to measure that I could get to. No 2.5 found anywhere, and now that I look at it, the dynomax setup seems like it will be way better than stock, I don't need stainless steel, aluminized steel will last forever here, the trick is to paint the welds. I need to spend some time under it and look at it closer and figure out what I want to do.
Now that is a 97 with a 4.6, not a 93 with a 302, there could obviously be differences. And the pipe after the split in the back might be 2.25, I couldn't get to it real well, I was doing this on my lunch break on a hot car :)
The 1995 NVMA thingy posted on SCCOA (I wish I could find it for 97) shows:
3.8 NA - 2 inch all the way
3.8 SC - 2 inch from manifold->2.25 intermediate->2 inch tailpipe (which could be after the muffler?)
4.6 NA - 2.25 from manifold->2.25 intermediate->2 inch tailpipe (which could be after the muffler?)
With variations for California, Manual tranny, that sort of thing.
The stock exhaust system at least on a 4.6 goes 2" after the mainfold to 2 1/4 then after the Y pipe it goes all the way down to 1 7/8 its pretty small
Crap, so that means I need to keep the PS pipe....
2->2 1/2 -> 1 7/8 is not going to cut it.
I'm going out there with a caliper tonight to measure it.
1 - 12 of 12 Posts
