I am currently rebuilding my 1996 4.6 engine. I am installing oem Ford rods for floating pin pistons.
My question is what is the pn# or the name, etc. of the oem floating pistons which would work for my npi headed 1996 4.6.
I would like same dish, stock compression, hyper pistons, (to equal the stock 1996)oem Ford.
Cylinder is not needing overbore.
While rooting around online, I saw oem pistons listed as Grade 1, 2, 3. I have no idea if this or how this applies to my particular situation.
My want is to do this build using all Ford parts for the minor mods to the more or less stock engine.
Thank you in advance
Discussion Starter #2
1996-99 Windsor Pistons?
From what I am finding, the 4.6 Windsor pistons for the 96-99 NPI cars may be the oem pistons that I am needing.
Does this sound correct?
Thank you
Found the oem part numbers, but failed to find any old stock avail. Ended up with the SP hypers, which have a very similar dish. -.140" vs the oem -.153".
Thanks
