Alright, In my 96 cougar the hazards do not work. but the turn signals do. where exactly is this located under the dash? and where can i get the part to fix this?? cuz whenever we turn them on, the turn signals wont work which is normal i know. but for an hour the day we bought it, we didnt know what the hell was going on.... thanks for the help!! :D
If you play around with the hazards swith do they work? How about if you have the car off (key not in run position) and hazards on, if you use the turn signals do they work (when they shouldn't since the key is off)?
My multifunction switch seems to be going in my 97 Cougar, causing the hazards to not work unless I fiddle around with the hazard switch and/or the MFS.
well i found the relay... and messed with it a little and now they work.... so I guess its fixed for now.... but if they go up again, im going to buy a new relay.
turn signals always worked. thanks for your help!
