After extensively digging through threads for a couple months, I'm trying to narrow down parts & materials needed for the HG install. I have a major fear of breaking bolts on this thing with no easy way of extraction. Otherwise I feel confident in performing the procedure. 93 3.8 NA block.
On top of having the Fel-Pro -5 upper engine kit, new rad hoses, & thermostat, I will be ordering two (4 in case of F'ups) full sets of TTY head bolts, water pump, coolant, oil, & oil filter for the job.
I think I should get the heater hoses replaced as well, anyone happen to know the size hose I need? While I'm doing the water pump, will it be necessary to mess with the timing cover? Not looking forward to that if so, darn thing is in the oil pan and I don't want to crack the seal on it.
I have seen others vaguely mention using thread sealer on some parts or bolts during the install. None have been descriptive enough as to where this would be applied or type of sealant used. I'm under the impression the lower bolts would be sealed due to being in the coolant cavity, to reduce risk of corrosion. I also need to confirm if & where any gasket sealant would be used on the lower intake manifold, as this would appear to be a main source of leaks. Then I ask what type of sealant am I looking for there. Am I missing any materials yall could think of that would make my life easier than running to o'Reilly every 2 hrs during the job? Thanks for your time.
